M35 won't steer to the right?
texascadillac42
Peoria IL
I recently fired up my M35 to move it up to my new place and noticed an odd problem. It will not turn to the right no matter how hard I pull on the wheel. Turning to left, full lock, is no problem, and returning to center is no problem, but turning right is impossible.
The truck steered fine in both directions when I last moved it several months ago. It has been relatively cold here lately, but I'm not sure how that would affect this. Any help would be appreciated, thanks.
mikew
edmond, ok
I think you're all wrong!
Obviously this is one of the very, very rare deuces built for NASCAR.... so it only turns left!
bones1
Southern Maryland
All your right turn air leaked out over the winter or someone used lefthand grease on the right side of the truck.. This only happens on days that end in a Y.:)
m16ty
218
Dickson,TN
There was an article in MVM awhile back about how to change a steering box in a deuce. His steering box broke and he had to change it. I believe I remember the author saying that his steering box broke inside and would only turn one direction before he changed it.
I'd try (as others have suggested) to thaw it out before I pulled the box. Those things aren't easy to get out.
MyothersanM1
19K M1 Armor Crewman
427
68
Culver City, CA
Nothin' a can of squelch juice and a right handed crowbar couldn't handle:wink: If not the crowbar try a left handed monkey wrench.
texascadillac42
Peoria IL
Steering box had water in it which was frozen. A magnetic block heater on it for less than an hour thawed it out and I'm back in business. Thanks for the suggestion.
m-35tom
222
eldersburg maryland
they are meant to have 90 wt oil. grease won't leak out, but it won't lube it either. of course, since these trucks were meant to last only 8 years, there was no need to make the seal removable while in the truck. duh. but really, it's not that hard to remove the box and fix it right.
tom
