M35A2 Air Assisted Power Steering Questions???
WhoMe08721
123
Bayville/NJ
Hey Guys,
I was thinking about installing a AIR O-MATIC air assisted power steering on my truck. But wanted to know some thing before buying and install one.
1) Is the AIR O-MATIC air assisted power steering worth the money???
2) Is the system reliable? and if the air cylinder fails when driving can you still steer the truck??
3) Has any one have issue with water in the air system with this system??
4) What the going price on a used system and NOS system?? I found a complete working used system for $1,200.00. Is that a good price???
5) What should I look at when buying a used system??
6) Are they hard to install??
7) Finally opinion on the over all system???
Floridianson
2,437
Interlachen Fl.
Been awhile but. Make sure you have a air cut off valve to the unit starting at the tap. It was said run the regulator wide open so it that's true you do not need the regulator. Instead install small water catch type of filter set up.
runk
65
Houston, TX
Here is a not too distant discussion with some good links -
My opinions (FWIW) on your questions-
Depends on the money, when a bunch of them were on the market 10-15 years ago, absolutely ! Recently new sets have gone for crazy money, maybe more then paying someone else to install a conventional power steering conversion.
System is reliable, and when it fails you are just back to the no assist configuration. But, the pressure protection valve is essential to preserve brake air if there is a leak in the steering.
Maybe. There have been some discussion on what causes failures in the non- serviceable drag link/actuators, and water contamination is a possibility.
That is pretty similar to what NOS systems were going for 10-15 years ago, when they were more available.
Drag link/ actuator is functional !!! Pressure cylinder is usable. Other mechanical mounts are present.
Drilling the hole through the frame for the air fitting sucks.
I love mine, maybe not as good as a hydraulic power steering conversions but way easier to install. Saves my poor old arthritic elbows
