M35a2 air compressor problem
Hottrodd789
Orlando fl
After my truck sat for two years I got her fired up now my air compressor runs Non stop and blows the pop off valve but my gage reads 0 and the buzzer dosent shut off and the tanks hold air where should go first replace the goviner ?
rustystud
2,862
Woodinville, Washington
Yes, check the governor. It probably has gunk built up inside. I would just buy a new one. There real cheap about $25.00 .
Warthog
232
OKC, OK
Or you may have a leak in the line somewhere. If the gauge is seeing zero and the buzzer stays on (because of very little air) then the air isn't getting to that part of the circuit.
It is hard to find a leak with the engine running. You can dig up a fitting for the glad hand to pressurize the system without the engine running. At the moment I can't remember which one to use. It has been years since I owned a Deuce.
The M809s are notorious for breaking the copper line on the tank drain. If you forget to drain your tanks in the winter time water will fill the lines, freeze and split the line. I know they are different than the Deuce but it is something to think about.
Jericho
69
Landaff NH
check the air pressure gauge as well for a leak on the pressure supply line at or near the gauge, Just had a bad one myself, very hard to hear it until its real bad.
Tracer
13,880
Hawthorne, NV.
When I got my deuce the compressor ran non stop, so I checked for leaks and found none, changed the governor and that fixed it.
gimpyrobb
dumpsterlandingfromorbit!
27,785
750
Cincy Ohio
If the pop-off valve blows, you have too much pressure. You need to find out why the gauge isn't working(reading pressure) and why the governor isn't working(turning the air comp off).
rustystud
2,862
Are you talking about the "pop-off valve" on the air tank ? That takes between 140 - 150 PSI before it blows. I agree with gimpyrobb , you have a couple of problems. The air gauge is bad and since you already replaced the governor that more then likely means your air-compressor "unloader valves" are stuck open.
