M35A2 Airpack?????
1,806
Folks, forgive my ignorance but isn't that the newer style? Wait, it is the newer style. The older ones were the long ones with the studs at the end of the air cannister. I've not found a source for rebuild kits for these. I do have one on the M108A2. BTW, Mark, I have recieved your air pack and will try to get it done this week.
1,806
devilman96
17
Boca Raton, FL
yep... SOmetimes I show my ignorance... Ok newer style... Sorry!!!!
I do know that both take the same rebuild kit, I have both styles and have gone through both of them.
WillWagner
2,554
Monrovia, Ca.
So, the black painted one in the above pic WILL bolt up to the mount for the one on the bottom?
1,806
Now that RAM brings up the point of OHT, the shorter pack doesn't have a plug to feed it, you have to remove the j shaped air line to put it in.
1,806
Pneumatic lube. It's use is essential to long air pack life. IIRC, 4 oz in the air cannister every so often. There is a PS article on it.
