M35A2 BRAKE MASTER CYLINDER TECHNICAL CHALLENGE
Valence
565
Davis County, UT
Has anyone ever talked about an emergency system that would apply the rear brakes if the system fails?
I have heard some folks talk about adding pinion brakes for emergencies. Of course they'd be 1-time use as they would require a rebuild/replacement after use since they would be spinning 6.5 times faster than the wheels (that's a lot of heat from friction).
rustystud
3,389
Woodinville, Washington
Almost every mechanic today has a bore scope. I should buy one of the newer models as they are even smaller then mine. I originally bought mine to check the valves in the engines I worked on, but it works on anything that I can fit the eye-piece through.
Chief_919
105
Western NC
I have a cheap borescope that hooks into any Android phone or tablet- for under $20 they can't be beat. you can use the cheap Android tablets or a phone with no service if you don't have an Android phone already.
I cant find the exact one I have but it is a lot like this one on Amazon: http://amzn.to/29PqHQQ
saddamsnightmare
82
Abilene, Texas
July 18th, 2016.
Maybe the new brake components can be sourced from Korea from KIA Motors Military Trucks division, as they are still building M35 and M715 derivatives from our original blueprints.....
rustystud
3,389
July 18th, 2016.
Maybe the new brake components can be sourced from Korea from KIA Motors Military Trucks division, as they are still building M35 and M715 derivatives from our original blueprints.....[/QUOTE
I've wondered about that for some time now. The Koreans make very good products, so I'm sure their military truck parts would be top class also. Now we just need to find out if they will sell any of them to us.
