dcwilkie
- 2
- 0
- Huntsville, AL
So I go to check the DOT 5 fluid level in the Cheetahmobile Deuce and all I see under the cover in the cab floorboard is this style of Master Cylinder.
The manual I have shows one that has two caps and the line with fitting.
Am I being to cautious? Should I just twist this off and all will be revealed? Is there a seperate reservoir I don't know about?
All squawks fixed now except the stiff brakes. The air gauge is only showing 30 lbs. and doesn't seem to move at all. Gonna bleed the air tanks after I check the reservoir level I guess.
All advice solicited!
