mitchsc0tt0
- 29
- 18
- Unionville CT
I have been in the process of trying to figure out what to do about safety on my deuce's single circuit brakes. I have 2 options right now and curious if anyone has done the 2nd.
1. Do the dual circuit M44A3 setup with 2 air booster packs and fabricate up some sort of mount for the dual circuit master cylinder as there are none available.
2. Found this while online doing research. See link below. But overall the concept would be to use a air brake chamber from a air brake truck to push the dual circuit hydraulic master cylinder and mount a treedle valve brake pedal. https://www.powerbrakeservice.net/aibrsyfordea.html
