M35A2 brake upgrades
nicholasktu
Fordsville, Ky
I just got a bone stock m35a2, great shape except for leaky wheel cylinders. I have to some NOS that came with the truck and all new brake shoes, but would it be worth changing the front brakes to discs while keeping rear brakes original? Or better to just go discs all around?
20,766
Pull out your wallet and see how much money you've got.
If you have enough, go for it.
Otherwise, maintain what you have.
Barrman
2,217
Giddings, Texas
The problem isn’t the wheel cylinder bores. The problem is the cups that hold the fluid back. When they get old, they get brittle and don’t seal any more. All you really need is a new set up cups, a drill with a hone and a place to work on them. Here is a rebuild video:
nicholasktu
Fordsville, Ky
Looks like I'll be keeping the drums, most disc brake kits aren't made to fit the stock wheels. The brackets used in Hank's Deuce project are no longer available, that fab company isn't doing truck parts anymore. With new wheel cylinders, master cylinder and booster I should be fine for normal driving.
nicholasktu
Fordsville, Ky
Only option for front disc brakes is the Boyce kit. I tried getting drawings from Black Rock Fab but they don't have any drawings either. There is a 15" conversion kit but it doesn't fit stock wheels.
