m35a2 diesel swap
Dan6wd
morehead city nc
i have searched for engine swap forums on here and have come up with little to nothing. i know the m32a3 comes with a caterpillar 3116 engine, but does anyone know of another type of diesel that would bolt up to the duece's 5 speed transmission? i was looking at the cat 3406e engine, however i dont think the duece's 5 speed would last under 600 hp pushing trhough it. so i supose i have 2 questions. 1. as i forementioned earlier, is there any other diesel other than the white/contenental/hercules that will bolt up to the factory transmission and 2. is there any other diesel and transmission combos that could easily be adapted to the duece? has anyone made a successful alternative diesel swap other than a 3116 cat?
Westech
CPL
6,104
212
cow farts, Wisconsin
the Deuce trans is only rated to 350 foot pounds or so. If your going to hop up the engine it would be best to install a new trans also. You can just about install anything you want if you are willing to put some work in to it. I have seen big and small block GM's, Mopars, 8.1 vortech engines, and many more.
CGarbee
594
Raleigh, NC
I recently looked at a duece that had a Cummins 6BTA installed... Sweet running truck, much more grunt on the low end, faster on the top (is sporting super singles) that is using the stock transmision. From what I understand from its current owner, a Guard unit did the swap in house...
I agree that if you are going to put a lot of engine in that you should go with a more robust transmision. There are a couple of threads on here concerning the instalation of different transmisions that might be of help...
