M35a2 Dump box and winch PTO?
Darrick23
Marshall Wi. 53559
I have a 1971 m35a2 with a winch, it is powered by the transmission pto on the drivers side.. I would like to also put a pto dump box as well on it,, is there another spot on the transfercase or transmission i could hook up a pto??
tie6044
42
Blaine, MN
Transfer case pto is the route I plan on going for converting a deuce to a dump, they can be expensive but I like pto driven over electric.
porkysplace
1,487
mid- michigan
You can also go with a belt driven pump off the motor , like this ;
Hydraulic Clutch Pump
Item# 1081
Each pump operates off truck or equipment engines. Mounted in line with engine belt 2 groove pulley. 7in. pulley diameter. Takes two type A 1/2in. belts. Clockwise rotation. Foot mounts with two 1/2in. holes. Maximum pressure 3000. 1 1/4 in. SAE inlet, 3/4 in. SAE outlet.
1,807
You can add an accessory drive to your existing PTO as well. A well known auction site around the world has one listed right now or you can run a wanted ad in the classifieds.
