ACB2seabee
- 0
- 0
- Pikeville/NC
I trying to install a new injection pump on a M35A2 but I am having trouble identifing what engine I have. This is due to the freeze plug behind the engine information tag leaking. The first digits go the engine identify are missing. I can see what appears to be LD then the 465-1C. I cannot tell if there is a T behind the LD. And according to the manual you set the timing different on the LDT and the LD. Is there anyway to tell the difference between the LD and the LDT without the tag. Thanks to anyone help trying to install this pump tomorrow.
