18operator
- 1,861
- 113
- Seville, Ohio
Hi all,
While driving my Deuce around today, I noticed a strange metal to metal sound coming from the engine compartment.
I found both top and bottom of the sheet metal fan shroud separating from the radiator. The bottom of which was rubbing on the crankshaft and alternator pulleys.
Now I realize I have to pull the radiator to repair the shroud, that's the easy part. The hard part is how to reattach the shroud back to the radiator.
Has anyone else had this problem before, and how did you fix it?
