m35a2 fuel mileage
JCKnife
46
Kentucky
I have never checked and don't plan to. WMO makes it run a lot cheaper than straight diesel, but like a sports car I didn't get it for fuel efficiency.
I probably go through 2-3 full tanks per year.
Goose2448
TEXAS Hanover, Pa/Bokeelia, Fl
I believe that the two stroke oil helps with IP lubrication to offset the (poor) lubricity of ULSD.
That would be correct. A friend of mine runs it in his 04 6.0 pansystroke when towing the 6K scout trailer. He gets around 20 MPG running that combo, vs 16 without. He has many other mods too it too. Im trying to get my uncle to run it in his 2011 Dmax, though I dont know if it would really help in that, he gets around 18-20 unloaded anyway. With only 92,000+ miles in a year and a half....
91W350
57
Salina, Kansas
I need to slow down on my running around, that is less than I burn per month...
Terexts
Winder, Ga
I drive my deuce to work about every week. I drive 50 miles one way to work and its mostly hills and some of it is flat. For those who live in Ga, I drive through Lawrenceville and Snellville, rolling hills for sure. I have the fuel turned up and on a hard pull up hill the egt's will hit 1050 pre turbo temp. My truck is a stock deuce with soft top, no winch, and dual tire setup.
Running 50/50 WMO and Diesel and 11.00x20 NDCC tires
2000 rpm/ 45mph/ 12 mpg
2500 rpm/ 55mph/ 9 mpg
JOEDEUCE
10
richmond va
I have been in the 10 to 11 mpg range so far.... Ive been running Lucas brand injector cleaner with upper cylinder , along withe the powerservice diesel kleen in the silver bottle..... So far so good..
beachbummer
Wilmington, Nc
reason
The reason I ask the MPG question is I will drive my duce a lot. More than likely EVERY DAY and will make several 300 mile 1 way trips with it to go camping. I have a supply of WMO and Tranny fluid. not mixed the tranny fluid would be nothing but tranny fluid. I was just asking to figure out how much oil and tranny fluid to take on. i do not want to get over loaded with either. and if anyone has a good mix of gasoline to WMO/ tranny fluid i would like to hear it also
