Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Hey Guys,
Was removing the radiator and thermostat today and notice that my intake manifold is a little mess up inside. Was this a bad casting from the factory or is this rusted out. Should I be worried about this??? Attached are some picture.
If coolant isn't getting into the air side of the intake, I'd clean it up and JB weld it. Maybe someone who has a spare one can look in it and comment.
The water manifold is aluminum so that is not rust. Just a bit of corrosion. If your really concerned you can take it off and sand-blast it. Then paint the inside with a good Aluminum primer and high gloss paint. There are several "freeze plugs" on this manifold. So this would be a good time to replace them all. I went with stainless steel ones. Also replace the hoses.
If you decide to replace it, I have some take-offs available. I can't say when I'll be at the barn to be able to get pics, to see if mine are the same internally as yours.
Was Able To Look At (4) More Intake Manifold This Weekend and I Have Came To The Conclusion That the Sand Molds They Use For Casting Where Not That Good Back In The Day And That Mine Way OK. I Also Finally Found A New Radiator For Sale And Got It Installed This weekend.
I think that is caused by cavitation in the water system. I would use some JB weld or use some Alum. Devcon. Then use a good epoxy paint on the inside.
theres a lot of copper there. I just purchased a small 50' roll of 10-3 romex......it was 85$. Radiators have to be sized to engine Liters, and physical size/fittings, so Big engines need more copper.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
