m35a2 loss of power
donnie1939
flintstone maryland
hi i have owned my m35a2 for a year now and about six months ago it started having a loss of power at hight rpm when i am in the woods it runs grate but on the interstate you can tell it use to run upto 2700 rpm but now in 3rd,4th,5th it will only run bout 2400 so any ideas thanks
mudguppy
15
duncan, sc
sounds like a lack of fuel. first thing i'd check is fuel filters. next, i'd check to make sure the lift pump is working. after that, cracked fuel lines.
stumps
12
Maryland
... and don't forget to clean out your air filter! The faster the engine goes, the more air it needs.
-Chuck
donnie1939
flintstone maryland
thanks all fiiters are new lift pump is working i had the pump out of the tank and found that the top clamp on the rubber hose was loose so im hopeing that is it i have not got a chance to test drive yet
stumps
12
Maryland
Yes, that needs mentioning too: 2700 RPM is a little bit above the redline for an LDT engine, and a lot above the RPMs you should be running if you want to have a nice long trouble free relationship with your LDT engine, that was probably assembled by some miscellaneous guy at Toole.
Check out all the threads that contain MF and rod...
-Chuck
