m35a2...No go no mo,,,,,
6x6jer
williamsport Pa.
The truck ran fine,, Would start good,,When I ran it. Started it, cleaned it up, drove it around, parked It.. 3 weeks later would not start, Only on starting fluid,. Changed fuel filters , fuel pressure to the pump nothing at the injectorsaua Have not tried much else.....Thanks
goldneagle
931
Slidell, LA
maybe shut off at pump is stuck !
Yep that happened to my truck a few weeks ago when jeepsinker was coming to pick it up. I wanted to get the truck running ahead of time so it would be ready when he arrived. We tried for hours to get it started. We even drained all the fuel and put new fuel and filter on.
When he got here he said it could be a stuck shut-off at the IP. I short screwdriver and 5 minutes and the truck was running! (he used the screwdriver to remove the small cover on the side of the IP.)
Warthog
231
OKC, OK
Cable is not directly attached to the fuel shutoff rod.
There is a sticky in the deuce forum covering the removal and repair.
Davis Welding
Colorado
Yep, the shutoff shaft can move freely in and out but the shutoff rod/lever can still be stuck. Pull the cover and have a looksee. If the lever and rod do no move freely, make it! ;) Good luck. Mine had a sticky fulcrum lever and sliding sleeve in the governor.
