Aussie Bloke
- 415
- 63
- Lost, out bush in OZ
G'day everyone,....
In the comment section BC mentions he would use a 50w oil but it wasn't available at the time.
Also in the vid he mentions that that's the type of oil the spicer gearbox was meant to use,....
I know gear oil has a higher shear resistance but if you used the 50w oil it would just mean you would change it a little sooner if that info is correct.
I don't think he drives it with the drive shaft exposed all the time but that was done for the vid while he moved forward a few meters to show it all works just fine after the fluid change.
Just my thoughts,....
Aussie.
Aussie.
