rustystud
- 3,389
- 113
- Woodinville, Washington
Thank you.Welcome back again.
I removed my message since it was off topic. Sorry.
Thank you.
From the pictures the studs don't look rusty enoughSo basically I got a "shell" . Now I've been installing the studs in the walls for wiring and insulation myself, plus that front concrete entrance the county demanded. Since I had my right knee replaced 7 months ago progress has been slow !
No problem.
Rusty, I had considered a 205 for mine but was concerned it may not hold up in a truck as heavy as mine. It certainly would improve ground clearance a lot.I bought one of the last kits from him. I needed two more so I contacted my machinist friend and tried to get some made. The main problem was the main shaft. Gears are easy to make, but the shaft is not. So I bought several new shafts and we tried to modify them. The main problem was reheat-treating them without distorting the shafts. There was a company in Oregon that said they could do it, but we never got the chance since my friends shop building got sold. He was already 68 and decided to retire. That was last year. He did get my modified NP205 transfer case parts made before closing up shop !
I've been working on replacing the Spicer 5 speed with the Allison 1000 automatic using a heavily modified NP205 transfer-case behind it. Should work pretty good.
I too at first disregarded the ability of the NP205 to handle the torque and power needed for the Deuce. But after researching it I found out it could be done.Rusty, I had considered a 205 for mine but was concerned it may not hold up in a truck as heavy as mine. It certainly would improve ground clearance a lot.
Can't wait to see it!!I have some pictures of my NP205 project but I was told to start my own thread and quit hijacking threads. So I'll post them later.
