M35A2 Parker Fuel Pump Install
153
NW PA/ Warren County
Hello All,
What’s the trick to getting the Parker 1C20-10 fuel pump to fit in the original mount? Either it’s too fat with the old rubber gasket and metal half moon pieces, or it’s too loose using just the new rubber gasket. The original bail just doesn’t seem to be happy. Anyone done this that can help?
Jeepsinker
328
Dry Creek, Louisiana
I don't remember ever having an issue doing it. I know I reuse the original rubber. Can't remember if I reuse the metal shell or not but I don't specifically remember omitting it. I do remember it being more difficult to clamp.
153
Issue I’m having is that my Parker pump didn’t seem to come with the metal ring that goes around the rubber mounting bushing. If this was with it all, it seems to me it would just fly together. The original pump is just a little smaller in diameter than the replacement it seems.
fpchief
218
South Alabama
Are you 100% sure that you have the parker pump that most of us have used? There are ALOT of different parker pumps. I have installed two of them and do not recall any issues at all with installing it. I literally popped the strap deal holding it in, took out a couple of screws and put the new one in. I replaced the rubber hose on both. Send pics if you need to. I just cant imagine it not popping right in.
Privatewrench
19
Kentucky
This is a pic of the parker pump I installed in my deuce. Snapped right into existing bracket with no issues. Does your look like this one?
Dukeman
Albuquerque, NM
okay, where are you guys getting these pumps. The only source I can find is aircraft supply and they don't want to sell to an individual.
Beyond Biodiesel
36
Prescott, AZ
Thanks for the great photos. I have a Parker pump I plan to put into my M756A2, but I don't get the electrical connection. It looks to me like you were able to switch the cable from the old Olympus pump to the Parker pump, which comes with a different electrical connector than the old deuce has. So, how do we make that cable switch work?
Beyond Biodiesel
36
Prescott, AZ
In that 1969 M35A2 the connections made up perfect. All of the Bradley Parker pumps I had all had the proper connection for that truck.
Thanks for the reply. My Parker fuel pump came with a bayonet connector, so I guess I'll buy a mating bayonet connector and connect it to the wires coming from the old M35A2 style connector and put that adapter into the fuel tank.
The other option is I noticed that the Parker fuel pump has a connector on the top side of it which could be plugged in the correct wire assembly with connector if someone has the proper wire assembly with the correct connector available.
