M35a2 passenger seat
M35a2duece
Eau Claire wisconsin
Hello. I have an m35a2. Completely stock. Wife hates riding shotgun cause the passengers side seat sucks. To me, looks like my drivers side spring ride seat would fit on the passengers side..... So. If I bought another spring ride seat, would it bolt in? Has anyone done this?
frank8003
4,983
Ft. Lauderdale, Florida
No, it will not "bolt right in" but it is worth the effort. Have to drill two holes and use good bolts. It does make it so much easier to work on the PM's under the tunnel pieces!
jbayer
St. Aug., FL/ McGrady, NC
Not a direct bolt in. Yes, with some drilling, and or welding. Yes I've done it. If you don't want to drill new holes in your floor(which I did not want) you have to weld on some tabs on the seat base to pick up the existing floor holes.
Same reason too, "happy wife, happy life".
M35a2duece
Thanks guys! That's awesome! Pictures are super helpful too! I am definitely gonna give it a try! Happy wife happy life is right lol. Means more time behind the wheel of the duece Lol.
1,127
My deuce had the standard spring ride drivers seat and passenger bench. When I got an M44A3 drivers seat, I put the stock spring ride on the right side. And it was that way for a year or so, until I rode in it while my Dad drove.
What I found was that the spring ride upright is sooo vertical, that without the steering wheel "holding" me in place, I felt like I was falling forward the entire time. It was not comfortable at all. I rectified this by putting an M44A3 seat assy. (without the base) on the spring ride base. Required adapter brackets.
YMMV
wreckerman893
Possum Connoisseur
15,621
2,025
Unless you are a purist this is what I did with the M109 deuce I had. I went to a body shop that had a bunch of junk Dodge Neons sitting around and bought a set of front bucket seats out of one.
I fabbed mounts for them from angle iron and used all thread and galvanized pipe (for spacers) to mount them in.
That was one smooth riding military truck.
rustystud
2,779
Woodinville, Washington
YMMV
Mine did the same thing, so I installed "shims" under the front seat bolts to tilt the seat back. Works fine.
