M35a2 stacks moved
msghall1229
Maine
Anyone moved stack on a a2 from side to behind cab. Making it into a 2 stack system. If you did where do you have it done?
NDT
6,486
Camp Wood/LC, TX
Welcome to the forum. I did what you describe. I used the stack that used to be at the fender. I cut it right after the 90 at the bottom and mounted it behind the cab. I left the part that attaches to the turbocharger in place. I joined the two cut pipes using a 90 towards the rear, a long straight pipe under the battery box, and a piece of flex connecting the straight to the turbo stub piece. Reduces the noise in the cab somewhat.
wreckerman893
Possum Connoisseur
15,628
2,047
I did it on my bobber. One of our fellow members still has it.
I fabbed the stacks from two Marine Corps HUMVEE fording exhaust pipes and ran flex pipe from the turbo to the splitter I made from scratch.
It sounded pretty good.
Tried to find a pic but no joy.
red
25
Eagle Mountain/Utah
Routed the exhaust on my old m35a2 to exit at the end of the bed. Stepped up to 4" tubing.
Ran it between the battery box and the cab floorboards.
ranchhopper
139
south elgin illinois
Here is the bobbed deuce I put a V8 caterpillar into since I had to raise the whole body three inches I ran a straight pipe under the cab and used a tee behind the cab for dual stacks sorry I didn't have a better picture.
