M35a2 stalling when hot?
JP871Racing
Forward Twp./PA
Definelty will do a pressure test too, good thing I just bought a new snap on tester. Do you mean is the truck building oil pressure? Because it is when I go to start it it's at 30psi, and when it's at idle it's at 45-55psi, and that has a brand new gauge and sending unit also. They didn't work when I bought the truck.
73m819
327
gainesville, ga.
In my opinion, this doesn't sound like a valve adjustment issue.
I think your dealing with a fuel system problem.
I would look at injectors and injection pump, a compression test wouldn't be a bad idea either.
Maybe start with a fuel pressure test.
Also the starting issue sounds like you are sucking air/loosing prim, the stall could be caused by a fitting or something a bit loose, that opens up when hot, allowing you to suck air.
andy3
12
Suwanee, Ga
Sorry, I was asking if the oil level rises after driving the truck. If I can quote Clinto there are 5 places that fuel can enter the oil on the truck. 3 of them are in the area of the IP & HH. If that is happening you would have low fuel pressure and be at risk of washdown/wear in the engine from thinned oil.
JP871Racing
Forward Twp./PA
That's something else I will do today, I'm gonna check all my fittings to see if any are loose. Plus check all my rubber hoses near the engine, one thing i haven't scrutinized yet. At least I know everything on the fuel tank and fuel pump are tight, so no worries there, but as far as the oil level, I haven't noticed any significant changes on the level, but what I can do is take a scribe or scratch awl and make a mark where it is now, run it for a few days then check it again when it's cold, if there is any difference, then the injection pump has to be the cuprite.
JP871Racing
Forward Twp./PA
I did see that in the tm plus I found the specs on what the pressures should be, correct me if I'm wrong but this is what I found:
Delivery valve opening pressure . . . . . . . . . . . . . . . . . . . .250-400 psi
O v e r f l o w p r e s s u r e . . . . . . . . . . . . . . . . . . . . 5 psi max.
Fuel pressures, minimum (after final filter):
700 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 psi min.
2600 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60 psi min.
Pressure regulator valve setting (all fuels) . . . . . . . . . . . . . . . . . . . . . . . . .20-21 psi
5,111
Those numbers are correct. I actually added a mech oil pressure gauge to my fuel filter housing on one truck after wiping out a HH. (Starved it for fuel) I never took it back off either because oil pressure gauges are cheap, and it's a nice quick indicator as to what's going on with the fuel system.
JP871Racing
Forward Twp./PA
That is such a great idea! I actually have an old mech gauge laying on one of my shelfs somewhere and I know it works. I'll have to plumb that in to the filter housing, because your right, that is the last thing I need to happened is fry a HH. It will give me a piece of mind when driving long distance. It's kinda off the subject but after doing more reading on certain posts on here, it seems advisable to get a pyro gauge for these trucks. I'm gonna start saving $ to buy a good kit from ISSPRO.
steelandcanvas
87
Southwestern Idaho
I have done the same thing to keep an eye on fuel system pressures. I used an 1.5" back mount gauge mounted to a tee. I removed the bleeder screw and placed it on top of the tee to retain the bleeding feature. The gauge has a 0-100 psi scale.
JP871Racing
Forward Twp./PA
I know I should have mentioned this way earlier in the thread so please don't bash me because I forgot, would running clean used motor oil have anything to do with my problem? Maybe the HH is acting like it's starving for fuel because the oil is to thick to run through it? Just still trying to eliminate having to dish out for a new hh
RAYZER
59
sanford/florida
Is your fdc bypassed?
Mine is and I've run filtered wmo of all different consistencies through mine without any Ill effect.
But it's best to run wmo mixed with gas or diesel 50/50, imo.
