- 2,054
- 59
- 48
- Milford / Michigan
So once the timing mark in the window is lined up, the red tooth on the HH gear should be one tooth to the rear. I havent messed with that or even checked that. 24 degrees would be quite a bit off. would it even run?
do you guys think if the pump is off that much it would effect my performance? Does the mark that is on now shows my timing is advanced too much, correct?
Maybe i should go after injector cleaning and balancing first? the engine does "hunt" sometimes at idle and maybe that could be an injector. If thats the case, maybe i should start off with that if its not too hard to clean and balance them, right?
