ODdave
- 38
- 0
- lansing michigan
So I allredy know the trans is prone to failing in the deuce but i was curious,
How offten do you see a broken Output shaft on one?
I finally got around to seeing what was wrong with my buddies truck after towing it home a few months ago and it appears the output shaft is broken. The trans looks brand new (truck was rebiult in late 80's) No chipped teeth, No excesive play. Is this common? i use mine pretty heavily and have had no problems, should i be concerend?
