M35A2 Turbo Leaking?
Karp
Oklahoma City
Hello all, I have owned my duce for about six years. I recently let the tires hit the ground check the fluids and unfogged the engine, after a deployment and two years of painting. no it not completely finished but its close enough to drive. Except on my little test drive around the block I notice allot of excess smoke I didn't think to much since the engine was fogged. But on further inspection I discovered the Turbo was leaking oil into the exhaust and causing the smoke. I am thankful I didn't go farther than the block, or the news would have read "Hick truck burning down interstate in OKC, film at 11"
But seriously I don't know about turbos! I am starting to read the manuals tonight and I tried searching for the topic. I hope someone can shed light onto this subject for me. Thanks from Karp of Oklahoma City
Karp
Oklahoma City
Smile-Z-Have Fun,
Sgt Karp, USAF
1981 Chevy Luz "Rusty Smoke"
1982 M35A2 "82K187" (formally belong to the 607 ACS in Spangdahlem, Germany)
jimk
47
Syracuse, New York
extended idling can allow oil past the seal. That can be considered acceptable , if not normal. You might have see leakage when sitting that will have little effect when running. Make sure the drain is clear (and the crankcase isn't full of fuel). The exhuast might take a hard pull to burn out everything... JimK
ken
27
Houston Texas
Karp, You will need to run it some what hard for at least 10 miles. I know this sounds crazy but,it will work. It has a laybrinth seal in the turbine side. After heat and pressure builds it will start to seal back off. After a few miles you will see less and less smoke.
This usally happens on the compressor side also. This is very common on these engines. Espacillay if they sit and idle for long periods.
3,164
Good advice Ken. Karp, RUN it hard, then see how it looks. Avoid extrerned idling, 3 min. MAX.
Karp
Oklahoma City
Ok I will check the fluids and run it around. I was just scared due to all the oil in the exhaust that it would ignite in the exhaust pipe and the thing would look like a breathing dragon down 35. I'll let you guys know what happens. Thanks
I did notice the oil in the crankshaft is newer looking and the oil leaking out the turbo is black like I need a oil change?
3,164
It's kind of normal to have a black looking slobber out the back side especially if all you have done is idle or no load operate it. It's black 'cause the soot in the exhaust makes it that way. It will most likely smoke and smell of oil when you start out and until it gets up to operating temp. Run it for a good 10 mile or so un interrupted drive. On the other hand, if you notice the smoke is getting worse as youi drive, you might have a problem. Keep an eye on it. Also, see these PS mag articles.
http://www.steelsoldiers.com/index....l_exhaust&name=gallery&include=view_photo.php
http://www.steelsoldiers.com/index...._oil_loss&name=gallery&include=view_photo.php
