M35a2 wont start and/ brake light problem
DanJP2
NJ
truck wont turn over I have lights and buzz thats all.
Battery 1 12.39 volts
battery 2 11.17 volts
Shouldn't that be enought to turn it over?
problem 2
I bypassed the brake light switch and still no brake lights. I tested the volts and got 15/17 volts on and off.
any detailed help wpuld be a plus!!
Dan
DanJP2
NJ
I have two 12 volt batteries that = 24 not two 24 volt batteries if that helps
airmech3839
Augusta, GA
no thats a standard set up.... if you get your car and put jumpercables on dead battery post AND ONLY DEAD BATT POSTS ten try and turn over if she cranks your batt is bad.. Probably has collapsed cell and wont get any higher even if charged... Been there done that... know what your going thru!!
airmech3839
Augusta, GA
each batt is 12V and has 6 cells at 2 volts per cell in each batt... one cell collapsed equals only 11V because it will read partial on that cell... f it is the big mil batt then check water level and then charge standalone with a trickle charger and if after sitting on charger you dont get 12V after you let it sit then you have a bad Batt.... recomend replacement
