- 1,063
- 11
- 0
- Warsaw, Indiana
Here are some pictures one of our deuces, implement trailer, and Massey Ferguson 1100 tractor after returning from a modified tractor pull. We just got this truck this March from Stout Field from GL. After using an M135 GMC for years on implement trailers, an M35 is a real power treat to drive! We have set up the fuel, modified the injection pump, and re-worked the heads a bit to give it better breathing.
The Massey 1100 has a 1968 GMC 478 cubic inch V-6 I adapted into it. The V-6 engines of that era are really good flat torque curve and horsepower engines. It is no problem to maintain 5 mph+ wheel speed during a pull. If we add magnum heads, more power up into the 250 horse range is available. We had never pulled the tractor before, and we were really pleased with 190% on dirt transfer sled with no weight/balance or drawbar modifications, and only turning 2500 RPM out of an available 3500 because it is set that low for farming, for which it is used every year.
Regards Mari
Regards Mari
