M35A2C Driveshaft U Joint Question
CH46
Thomson, GA
1987 M35A2C Driveshaft U joint on front side of transmission: One of the needle bearing caps came out while driving on highway. Pulled over. Could not find it. Are the needle bearings and cap an over the counter item in the local parts store, or is it a special order item? Part Number? Can you buy one cap or must you buy the entire u joint? Thanks for any advice.
