M35a2s with Dual Circuit Brakes by Year?
dessertrat
13
Eagle Mountain, UT
Hi all. I'm finally looking again at getting a truck after a long pause. I figure if I ever have a chance to get one of the rare M35a2s with dual circuit brakes, I'd jump at the chance because the idea of single circuit brakes on a beast like this does give me a lot of pause and makes me lean toward an M923a2 for the air brakes. But I keep coming back to the Deuce for a lot of other reasons.
The problem is I'm not sure exactly how to filter for trucks that are more likely to have dual circuit brakes as I search and keep an eye on sales. I've heard that basically any M35a2 manufactured 1987 or later was done for the Air Force and has dual circuit brakes, but it's not clear to me if earlier years could possibly also have been built with dual circuit brakes or if it's purely only 1987 and later. Some people know to advertise dual circuit as a selling point or to respond accordingly when I ask while others just know military truck make big noise and that's it.
Does anyone know definitively if it's purely only 1987 and later or if it's possible to find one from earlier years? And if so, anybody know what the earliest year for dual-circuit brake equipped M35s might be? I searched the forum and only found what I've mentioned above, plus it should have some kind of tower sticker in the cab, will have a hard top, and it's more likely to have a stack lid? Any other signs?
I know the a3s also have dual circuit brakes, but if I'm going M35, I'd really prefer the multifuel engine and to drive manual. And sure, I've heard people talk about doing aftermarket dual circuit brakes, but that sounds like an even more rare situation since it's more than simply slapping on new parts.
Thanks.
HDN
5,576
Finger Lakes Region, NY
There was a thread in the hotrodding board about adding aftermarket dual-circuit brakes to the truck. I don't think it ever reached a good solution.
With how prevalent computer-aided manufacturing is along with robotic machining equipment and metal 3D printing, I feel like it's about time we've reverse-engineered a dual-circuit brake kit for on-demand production. I'd love to make one for the older 5-tons too.
peashooter
210
Hanover, minnesota
I have only seen 1988 models of the m35a2/m109a3 trucks that have the dual circuit brakes but have heard mentions of 1987 & 1989 as well. The m35a3/m109a4 trucks of the early 90s had dual circuit also but not manual transmissions.
The only goofy thing that came on my 88 truck that stood out was that it had factory installed reverse lights mounted but not wired to anything. Otherwise it looked perfectly normal from the outside. It came from the military with a soft top and no exhaust flapper so i wouldnt spend too much time focusing on those.
dessertrat
13
Eagle Mountain, UT
Thanks for the insight, fellas. I'm looking at a local five ton and a 1982 M35a2 that's a state away, so based on the year I'm pretty certain it wouldn't have dual circuit brakes at this point. In spite of that, it looks like a great specimen. So we'll see. Hopefully in a few weeks I can post something to the Member's Rides forum either way.
HDN
5,576
If it were me, I'd get the 5-ton as long as I can drive it and get it titled, and depending on how far away it is. There's a lot more truck to the 5-ton. The one you're looking at has power steering and air brakes, plus it should have super singles. It has an automatic transmission too, but if it's anything like the M35A3, you should be able to downshift manually for engine braking.
