M35A3 Air Pressure Relief Valve.
penokeevet
Penokee Range, MI
The Air Pressure Relief Valve on my M35A3 keeps popping off frequently - every minute or so when driving or idling. Tire pressur is set for highway driving, could this be the problem, or is this normal? Thanks.
penokee
ps: Newbie here, so hopefully posting on correct forum.
Deuce007
North Dakota
I have also had problems with the pressure relief valve. But instead of popping off, whenever I shut off the truck it slowly leaks air.
hemichallenger
deland fl
Most likley the unloader valve is not shutting the compressor off so it just keeps building air even though the air govener has tryed to shut it off. The vavle gets rust in it from sitting.
Floridianson
2,522
Interlachen Fl.
You talking about on the air tank or the air dryer. The air tank has a saftey and the air dryer has a purge valve. The Gov. controls the unloader valve.
Rustygears
Ramona, CA
Are you really sure it's the pressure relief valve? There's two, one mounted on the dryer and most trucks have a mod (MWO) to put another one right at the compressor outlet. They are set to blow at 150psi. The occasional air escape heard is likely the dryer cycling. The dryer under the truck near the spare tire purges itself every time the compressor governor unloads (shuts off) the compressor when the tank reaches 125 psi. When that happens, the excess air in the compressor lines is diverted through an alternate path in the dryer to vent the accumulated snot and moisture out of the dryer overboard. This is the pop and hiss you hear. You will also hear something akin to air brakes pressurizing when the air pressure drops to 90 psi and the compressor kicks in. That's when the dryer resets to dry mode and the lines start to fill up.
All of this function is controlled by the compressor unloader, a little doodad mounted on the side of the compressor and has, as I recall, 3 pipes attached to it that run towards the rear of the truck. One is the compressed air outlet to the dryer and wet tank, one is the dryer control and one is the pressure sense line to control the unloader.
A normal A3, once initially filling the tanks and reaching 125psi, will purge the dryer. The compressor/dryer should not cycle again sooner than 10 or 15 minutes at idle with no brakes applied or steering wheel movement. If yours cycles more rapidly, you have a significant air leak that should be looked into because it will cause problems with the dryer, which causes other issues. The really common air leakers are the steering regulator and steering drag link and just general loose plumbing fittings throughout the system. There are many posts on these culprits that can be found by searching. For most air system issues, the truck line pressure gauge in the dash and your ears are the primary diagnostic tools. Significant leaks can be heard and you should see no drop in gauge pressure when the engine is idling or off given with no brakes applied, etc.
Also, make sure you have properly serviced the dryer filter and desiccant cartridge. The leaky air systems really gum them up and in turn, pass lots of snot and moisture into the truck main air system. That will screw up the CTIS and other stuff, rust the drag link of the air assist steering, etc.
penokeevet
Penokee Range, MI
Thanks all for your comments. I have the Duece in storage in northern MI, while I enjoy the AZ sun. Will take it out of storage in about 7 weeks and follow-up on your comments/recommendations. Plan to sell it this summer, but would like to get this problem resolved first. At 76 it's getting a little tough to crawl around the Duece, will keep a M1009 and M725. Thanks again for all your comments/help.
penokee
