M35A3 Finally got mine!
Silverback
Cleveland Tn
WyoDeuce, running the CTIS on cross country is much too low pressure for highway use, highway use is 45 psi, max pressure is 80 psi. Don't run below 45 psi on highway, yes they ride a little rough, but they are a deuce, they are going to ride a little rough unless you have a load in the bed. You don't want to blow a tire on one of these, especially a front one, ask me how I know. Too much bouncing around could indicate that you have run flats in the front tires, check and see if the front tires have imprints from being on the spare rack, sometimes the spares have run flats in them and can cause the bounce effect. The front tires on the M35A3 should never have run flats, that causes bouncing and steering problems. HTH, Dan.
