M35a3 flywheel house
ROARKY
Purveyor of rusty iron
88
99
33
Flemingsburg, KY
Good morning everyone! I am looking at an a3 that has a busted flywheel house where the starter bolts to it. It was wrecked so I am a little concerned about what else might be damaged due to the force it took to crack the housing. Where else should I look? Also, what is a good source for that housing? I would need to replace the steering gear, drivers suspension and shock, oil pan. Also have to replace the fender. Hit was on drivers side. Also, what is the max that should be paid for this? Rest of truck seems to be ok.
E18A9D56-43C9-4D80-A539-2A43EBAF1B37.jpeg2E350F01-CF2B-47D1-A3EB-045732774E23.jpegF876D8FB-704B-4550-8ADE-8DCCEE1CF37A.jpegA3E9A8E0-A854-4188-83A7-F919E5BB99A8.jpeg
ROARKY
88
99
33
Flemingsburg, KY
Sounds to me that this is now a parts truck. I wouldn't touch it unless you intend to part it out.
yeah, I considered getting it if the price is right and pulling the engine and transmission so I can check them out better. Engine was running still after the wreck I was told. I may be mistaken, but I believe I’d have to pull them out to change the flywheel housing anyway. I’ll take frame measurements and do a more thorough inspection then (if I’m able to buy it). With it in its current condition any idea on pricing? I have a rough idea what I could part it out for and it’s more than the asking already but I want to make sure I am thinking sensibly.
HDN
5,077
Finger Lakes Region, NY
I agree - definitely a parts truck. It could be a fun project taking the 3116 out of this truck and putting it an M35A2 with a broken motor and coupling that with a ZF transmission like that M35E3C I saw awhile back. Or put it in the dead M54A1 listed in your signature?
As for buying the wreck - maybe pay $2000 or less for it?
davidb56
1,237
Bonners Ferry Idaho
2-3K$ if you can do all the work. at that price, there is no risk. The owner may consider parting it out himself if you go too low. but a 3 grand offer would sway most from the bother of hauling a carcass away after the vultures pick at it. just make sure the Frame is straight unless you have the tools to do it.
WillWagner
2,737
Monrovia, Ca.
We have an A2 900 series dump truck at the Museum. Took a hit on the drivers front, just like the one pictured. Ripped the knuckle off, tire/wheel/knuckle are in the bed. Broke the FW housing, engine gear housing, trans bellhousing, output housing, spring and hangar and more, but the truck doesn't look that bad....until you start looking at it.
I agree, a parts truck.
glcaines
2,593
Hiawassee, Georgia
If an insurance company is involved, the insurance company likely owns it now. If the guy still has it and no insurance company is involved, show up with $1500.00 in cash and see what happens. You can always go up. I would say $3000.00 is max, but I personally wouldn't go over $2500.00. You are talking about a lot of labor.
ROARKY
88
99
33
Flemingsburg, KY
Oh well, it sold yesterday. I asked the guy for pictures of underneath the engine and transmission so I could see if the frame was tweaked. With that kind of lateral damage, I figured there was more shock damage somewhere. Never got the pictures though. On toward the next project!
  • Like
Reactions: HDN
