FSO is an Eaton/Fuller trans; S=single countershaft, O=overdrive (if non-OD, then it will just be an 'FS' trans). then the numbers are like 5065, 6085, 70-something and on...
the first number is the number of gears; 5, 6, or 7. the next three numbers are the torque input rating; ex: 085 = 850ft-lb. lastly, there could be a letter after which would designate the gear ratio group if there were options.
so an FSO6085A is an OD 6spd, rated for 850ft-lbs, with gear ratio package 'A'. same nomenclature scheme that Eaton/Fuller uses for the rest of their trans lineup.
yes, the ZF6 was mostly used behind the Ferds diesels ('99-'10) but was also used behind the D-max for a while, can't remember the years right now.
but the ZF6 is big...
