M35A3 smaller steering wheel
wmmscott
22
Jeffersonville, IN
I have an M35A3. It has the same large steering wheel as the previous M35 versions, but the previous ones did not have power steerng, as mine does. I am looking for a smaller diameter steering wheel because of my gut size. I know that the M800 series trucks use the same mounting, but their steering wheel is only about 1" smaller. Can someone tell me what may mount up but is 3" or more smaler?
JJensen
Kansas City, MO
You can take loose the colum mount and lift it and redrill the holes and gain about 2 to 2 1/2 inches.
I haven't looked, but I assume that you take it loose at the firewall and the dash? Or is it not even bolted at the firewall? I need some leg room, and this will help.
redthegreendog
clarkesville, GA
I've driven then and worked on them. they have a wheel like the one in the Humvee. just make sure to turn on the air to the power steering assist. its a real B@%^& to turn without it. Trust me I've done it.
R Racing
15
St. Leonard, MD
Yes I have seen on M35A2s and 5 tons were the shaft mount has been lifted up tight against the dash and the holes redrilled to give more leg and belly room.
glcaines
2,448
Hiawassee, Georgia
My A3 has a smaller diameter wheel than my A2. I'm travelling at present so I cannot measure the two wheels. Two inch smaller diameter sounds about right though.
JasonS
126
Eastern SD
How does this work on the M35a2 where the steering column is one piece all the way to the box?
R Racing
15
St. Leonard, MD
The A2 I saw it done on had a upgraded power steering so it didn't use the 1 peice unit. It was closer to the 5 ton set up and used a aftermarket box. Sorry if I made it sound like you could do it to all A2s . But were there is a will there is a way ;-)
Welder Sam
Glendale, Arizona
Theres plenty of want to and ability here. Not to mention the fatboy issues that make it a Need to. Im wondering if a u joint set up would work nicely? Could put it in anywhere thst theres easy access to the shaft. I would think a tractor pto shaft type would be plenty strong
glcaines
2,448
Hiawassee, Georgia
Curious if there would there be any highway benefit with the older a2 wheel on my A3?
The only benefit for using the A2 20-inch wheel instead of the A3 18-inch wheel is more leverage when turning the wheel. If your Air-O-Matic is working, you don't need the extra leverage and all you do is minimize the room behind the wheel. I've seen a lot of NOS A3 18-inch wheels for sale if you want to change it out.
motomacguyver
Eau Claire, Wi. USA
Not to Hijack, but Does anyone have a steering wheel puller they would RENT to a reputable member?
FWIW, I have listed a couple of things in the classifieds for free lately, just a way of "paying it forward"
Thanks in advance.
