M35A3 soft brakes
BIVONA
Spring hill, Florida
I recently purchased am M35A3 ...I am new to this style of trucks ,but not large trucks in general.I drive trucks that have air brake systems.The system on this truck has a soft feel to it(deep depression before they engage) is this common for this type of truck/system?
maa45069
61
cincinnati/OH
Not mine... Mines the a2 but I get good pressure after air builds
Sent from my D6503 using Tapatalk
BIVONA
Yes I was told once the air pressure builds to 90/100+ pounds ,the air assist will help in stearing ..put I am not familiar with air/hydraulic systems...breaks....since this is my first deuce.Any advice on how to remedy the "soft" feel?Could this be a simple fix such as just replacing the break pads?
maa45069
61
cincinnati/OH
Did you check the master cylinder for fluid? There are a bunch of threads. I had bled mine it did wonders. Dot 5 fluid
CARNAC
The Envelope Please.
617
Corpus Christi, TX
I break air at about 30 psi cause I'm so old. As for my truck, I have air over hydraulic brakes that occasionally break but that the breaks.
porkysplace
1,485
mid- michigan
The A3's have a split brake system (duel master cylinders)
BIVONA , welcome to SS.
This TM will give the guidance you need for the brakes.
Deuce dual brake system TM
and this TM is a must read for new M35A3 owners
TM9-2320-386-10.pdf
TM9-2320-386-10 Operator manual for the M35A3.
And at some point down the road you will need these TM's.
TM's ending in -P are parts TM's and include part numbers.
LO9-2320-386-12.pdf
LO9-2320-386-12 Lubrication order for the M35A3.
TM9-2320-386-24-1-1.pdf
TM9-2320-386-24-1-1 Unit, Direct and General Support Maintenance TM for the M35A3 1 of 2.
TM9-2320-386-24-1-2.pdf
TM9-2320-386-24-1-2 Unit, Direct and General Support Maintenance TM for the M35A3 2 of 2.
TM9-2320-386-24P.pdf
TM9-2320-386-24P Unit, Direct and General Support Parts and Special Tools lists for M35A3.
The soft feel could be it needs bleeding or the brakes need adjusting or possibly more extensive brake service .
BIVONA
TM9-2320-386-10.pdf
LO9-2320-386-12.pdf
Thank for the information sir🇺🇸
