m35a3 tacometer
AceHigh
31
Lake City FL
my tacometer on the A3 quit today checked wire plug in and it is charging an Ideas???
Not sure what you mean that it is charging. Anyway, the A3 tach gets 24 volts from the system, has two wires to the sender in the bell housing and that is it. Sometimes the sender gets a little loose and does not receive the signals (one pulse per tooth on the flywheel) and sometimes it is a connector problem.
They are not easily available on the market so you will have a time if you can't get it to work. I finally bought a civilian unit with a digital hourmeter, it is working great.
RIDDLE1
Americus GA
I would pull the sensor out of the bell housing and check to see if a piece if metal is stuck to it. It is a magnet and the metal would cause it to stop reading the teeth on the flywheel.
AceHigh
31
Lake City FL
Riddle is right. The sensor is real easy to remove and check- if you have the engine and transmission lying on the garage floor. If not it is kind of tough.
You can get to it by going over the driver's fender. You will see the two wires going to the bell housing. Or, you can remove some of the firewall plates and get to it from the cab.
RIDDLE1
Americus GA
Haha! Yea it is not very fun to get to. I went over the fender.
Z71
FL, USA
Tacometer? Is that the instrument which displays the total number of tacos you have eaten while drivng your deuce? :mrgreen:
doghead
4 Star General /Moderator
1,191
NY
Yes, They had them at the restaurants that I ate at while out in San Diego.
gungearz
northwestern indiana
No, no, no, a tacometer is the meter on your dash that tells you how many tacos it takes to make for your deuce to run. I don't know what he's talking about. He said he has an A3. Tacometers are on A2's.
