M35a3 trans troubles
Digger09
New Jersey
I've searched through some old posts stuff like that and havent had any luck finding answers to my strange problem. The trans was working fine now for some reason all forward gears and neutral make the truck creep backwards. Its like half speed of normal reverse which seems to be working ok. Any ideas of what it could be are appreciated. I dont see anything in the linkage that looks out of place. I had someone shift through all the gears and watched the linkage and it all looks correct.
AceHigh
31
Lake City FL
Are you near an Allison dealer? Maybe just tow her in for diagnosis. Are you still running motor oil instead of trans fluid? I doubt that would be it, but I never liked the idea of the motor oil. Hope it is something simple.
rustystud
3,392
Woodinville, Washington
Sounds like you have a sticking valve in the valve body. Replace all the fluid and install new filters. Use Dexron 3 or better (don't use Dexron 5 though) in the tranny. Drain the "Torque Convertor" also.
