M35a3c won't run after storage (???)
kawhill
Windom,KS
Greetings,
M35A3C with Cat 3116 engine sat for six months without running. Cranked it and it lit and started immediately. After about
ten seconds began to sputter and then died. Pulled fuel filter and it was dry. I've read the TM's and the posts here, but don't
know where to start checking. Obviously no fuel to filter. Machine is stock from GL with original Kevlar fuel hoses. I don't know,
air leak in fuel lines from tank? Any info that could be provided that would help me get this beast running before winter would
be most appreciated. Best regards.
Kawhill
kawhill
Windom,KS
Thanks much steelandcanvas and warthog. Clean check valve and pressurize tank. Runs like a striped ape. Thanks
and you have my best regards.
Warthog
231
OKC, OK
The check valve is on top of the fuel tank on the M35A3
Item #24 in the diagram
