gonorth
- 0
- 6
- Rochester, MN
I bought a couple of M37 last Saturday. Pics and story are at the link below if you need to see them. These vehicles are in excellent shape but have been stored indoors for at least 20 years. I knew the previous owner and an confident that these ran when put into storage.
I oiled the pistons via the plug holes before cranking, put in new plugs, changed oil. I messed up the plug wire to the front plug so that is a cobbled onto the plug, that may be a in issue yet. Is it possible to redo the end of one of those cables or am I stuck buying a new cable?
First the fuel pump. I drained the fuel tank and put in fresh. Then sucked the new fuel up the line at the fitting going into the carb. The primer lever on the fuel pump does not work, has very little resistance when you move it. I was getting a little fuel out of the line to the carb when I cranked it but now there is nothing. So, any ideas what I am in for with the fuel pump?
Second is the carb. I can get the thing to run while spraying carb cleaner in the mouth of the carb. I hooked up a boat gas tank to where the pipe from the pump would go into the carb and squeezed the builb while running the engine on carb cleaner but as soon as I quit spraying the engine would quit. Maybe stuck float. Any ideas appreciated?
Second truck, only as far as oiling the cylinders on that one so far. Drain plug on the gas tank is messed up, can't get a wrench on it. Might have to drill and easy-out it.
Link to thread in the M37 forum:
http://www.steelsoldiers.com/m37/52476-bought-two-m37s-today.html
