deuceman51
- 10
- 18
- Scotland South Dakota
I just bought my first M37B1. It's a 1962, with 5800 mi on the odometer. Problem is, it doesn't run worth a dang. I can get it to start with the choke, and sometimes it will go for a bit, but as soon as I start to drive she starts to sputter and kill out (usually in the middle of a busy intersection, lol). When I got it home, I changed out the spark plugs, put in fresh gas, and put Sea Foam carb cleaner in it. As soon as I got it started it smoked like crazy from the sea foam, which is what it should do. We took it for a test drive and I got about 4 blocks from home and she died on me. Could only get it to start for a few seconds with the choke out fully. Sometimes it will start and idle just fine, but if I step on the gas it sputters and dies. My guess is that my carb needs a rebuild. The other problem I have is my oil pressure is nothing at idle, if I step on the gas and rev it up I can barely get the needle to move an 1/8 inch on the gauge. I'm hoping the gauge is bad since most of the wiring is frayed and bad. It has a few oil and coolent leaks( I can see drops on oil in one place and antifreeze in another spot on the bottom of the oil pan). Does anybody have any advice or have dealt with these problems before. I find it hard to believe that an engine with only that few miles on it can have so much wrong with it. Any help would be appreciated.
