I'm not aware of anyone producing them new. There may be an NOS tank out in the world, but a good used tank is probably your best bet. Someone has used a fuel tank from a newer civilian truck - IIRC, it was a tank from an Isuzu Trooper/Rodeo, or maybe a Chevy S-10 pickup?dose any one know where to find a n.o.s gas tank or next to new for the M37
Do you have a model and year range on that van? Is that a metal tank or plastic? I'm thinking of changing to a plastic tank and have been looking for a civilian equivilant.I used a tank out of an 80's chevy van on one truck. You will have to use longer bolts on the straps but the vent and filler holes are the same size and location. Lately we have been cutting them open and sand blasting them and welding them back together then use sealer on the inside but if it has rust holes fiberglass the out side first then seal. I had one repaired like that for about 8 years before i sold it and currently have 3 in the fleet like that now.
