M38 Using inverter
Boatcarpenter
Marlborough, NH
jackthebear46,
Are you looking to get 110volts from an inverter that has a 12 volt input? If so, and you will not be drawing too much, then just hook the inverter to the battery that only gives you 12 volts, which BillF says is the #1 battery.
BC
