M38A1 Antenna
tbanks
11
Winchester,KY
antenna
What antenna and mount is determined by what radio you have or what era and designation your jeep is.For instance the most common probably is a MP-50 antenna mount with an AB-15 antenna base with apropriate length antennas MS-116,117,118,AB 21,22,23 depending on the freq range of your radio.If you just want an antenna set up then go with the MP50 mount,AB15 base,1 MS116,1 MS 117,1 MS 118 antenna sections.That will let you whip it over if you wish.
