M38A1 Engine Hoist Point
Big Spur
Yorktown, VA
I don't see an obvious lift point to take out my engine. Am I missing something or is there an somethibg I need to bolt onto my motor in order to safely lift it? Thanks from a new guy.
FrankUSMC
30
Newport, NC
Yes, You are missing the engine lift bracket that bolts onto the engine. Maybe some one will post what it looks like, or you can find a photo of it in the manual.
I think I have one here on the loose somewhere.
One of the few, Frank USMC RET
1,140
What you should have is this lifting bracket, like Frank described:
This is what I did with a customer's Jeep that was missing the bracket. Pulled a front and rear head bolt. Hope the head gasket doesn't leak when I put it back together but it's a chance I had to take.
EDIT: B2U added much better pictures while I was looking for these. Thanks!
