M38A1 MRC 83 100 amp system
battlecr
49
Eugene, Oregon
Looking for a wiring diagram for the 100 amp system. I have a 1964 Marine Corps radio Jeep that was partially disassembled and parts missing. I have most the parts for the 100 amp system but need to hook it up to make the unit charge. Any insight would be appreciated. Most the Collins wiring is there.
Don G
NDT
7,518
Camp Wood/LC, TX
Your 100 Amp system is the early version without the aircraft type Cannon connectors right? Unless you are going for restoration perfection, I would lean towards upgrading to the later version with the Cannon connectors so you get get away from the selenium rectifier which is unreliable.
battlecr
49
Eugene, Oregon
My Jeep is a 1964, as I understand it mine original had the 150amp unit with the generator, rectifier and regulator in one. What I’m going back with is the 100 amp generator, the later rectifier an solid state regulator. I’m using a wiring harness from a 1952 radio Jeep. My problem is I need a diagram with labels so I can excite the generator so it will charge.
Don G.
NDT
7,518
Camp Wood/LC, TX
The regulator plug will have one 12 GA wire, that is excite wire, you will probably need to splice that in with the wire that goes to the ignitor.
NDT
7,518
Camp Wood/LC, TX
The connector you are holding in your hand should have some heavy gauge wires coming out of it and one 12 ga wire, that is the excite wire.
battlecr
49
Eugene, Oregon
Still trying to get the generator to charge, other than that she’s mostly done. Have most of the canvas too.
JEB
168
Colbert, WA
Nice looking Jeep. Is it an original USMC unit?
It looks like you have had a milder winter than we have up in Washington.
PS. My hat's off to anyone who can restore a Half Track. That is hard core MV work.
battlecr
49
Eugene, Oregon
This was earlier this year, about 20’ right now. Yes this is an original USMC Jeep, was in an artillery unit in Pasadena CA. Sb- Battery B. Have the T I sheets.
