m39 vs 800 series master cylinders
davesgmc
131
Mclouth, KS
Is there a difference between the m39 series 5 tons and the 800 series of 5 ton master cylinders?
AND is there a commercially available rebuild kit available for either one?
Mine is leaking and I thought I would source a replacement and rebuild it and my leaking one to put into parts storage.
any info would be appreciated,,,,and YES< I USED THE SEARCH FEATURE ALREADY and found NOTHING except people telling others to use the search feature.
juanprado
2,711
Metairie/La (N'awlins)
Does the master cyl have casting numbers anywhere on the body? If so, a parts store might be able to come up with a kit.
If you do get a number and the part stores can't help call Wagner or Raybestos tech support numbers. Those cyls look like they were also used on commercial vehicles.
davesgmc
131
Mclouth, KS
I have not ever found a parts counter guy that is smart enough to find hard to find parts. I usually end up finding them myself. as far as ever calling a tech line from a manufacturer. Might as well as talk to a kindergartner, they will give you about as good of an answer as any tech support person will. I had been an automotive tech for a very long time so have had to deal with both. Best bet would be a manufacturers catalog with specs in it, and those are disappearing quickly and turning into on line crap-a-logs. I was just hoping someone else had already found a part #.
juanprado
2,711
I totally understand. I am an ase parts spec formerly in the business for 20 years but had enough. I learned the trade with illustrated parts guides and catalogs and getting dirty id and cataloging cores to return. Yes the newbies only know computers and even NAPA is now harder to find paper catalogs. I do have friendly contacts that let me use their catalogs & tech lines. If you find a casting number, I will try to research it for you.
Juan
juanprado
2,711
mst cyl kit
l came up with a bore of 1 3/4 for Wagner Casting Fe 1575
Raybestos Master Cyl kit is a MK430. Napa is a United 430. (same part different box for Napa)
Raybestos tech support 1-800-407-9263
If is correct, please post to the parts sticky spreadsheet so everyone can find it.
Good Rebuilding!;-)
