M416-A1 rebuild in progress!!!
Datajockeys
Madison, AL
New can be functional used replacement too. I have seen axles on Craigs List going for $50. Doubt you can get one re-milled for that price. Sorry for not being more specific. Remilling was my first thought but then cost of transportation and the milling itself seemed a little high.
2ndchance
Glendale, AZ
If you are not trying to do an original restoration, you can just replace the axle. Some folks have ordered traditional 2,000# axles and added electronic brakes. Most axles can be had for under $150.
Personally, I don't think it looks that bad. I saw a guy hook an electric drill with "some" adapter to spin the spindle, and put polishing compound on a cotton rag. He spun the spindle and held the rag on it until he smoothed out any rough areas. It didn't take much. Just MIC it out and see how bad it is. If not, I would smooth it out, replace all the bearings, races, and grease seals. Pack the heck out of it with grease and reassemble.
If there is a trailer or axle shop in your area, consider having them just replace the spindle. They can cut it off and weld on a replacement. Cost is around $70.
2ndchance
Glendale, AZ
I almost had to replace one of my drums/surge brakes. When I took it to Arizona Axle the owner said that Dexter makes a replacement. Basically, it's the same setup used on most boat trailers. I don't have any measurements or model numbers so I'm not much help on the axle. If you take your axle to an axle or trailer shop, they can take the measurements and recommend a suitable replacement. Most will scratch their heads when you call and tell them it's for a M416 military trailer. They don't have specific measurements, either.
trailita
Atlanta,ga
hi
I,m restoring a 1967 M762 military trailer. I want to keep the brake system but my hand break assembly is totally busted.
anyone with a good one who wants to sell me?
thanks in advance
foxtrotavery
Winterville,NC
Just got a Parkhurst M416a1 trailer and was wondering if you would share where I can find the PDF data plate info. My plate is practically eligible. Any help would be appreciated.
2ndchance
Glendale, AZ
Hello Foxtrotavery. I was never able to find one so I hired a company to reproduce one for me. I made 20 of them but sold them all off back in 2015.
foxtrotavery
Winterville,NC
I have a Parkhurst M416A1 that I am in the process of restoring. I see that you said you had a PDF file for the data plates. I called Parkhurst and they said they didn't have any info. and they had sold the rights to the trailer to some company in Canada many years ago. Coud you give me the source of your PDF files or send me info? My data plates have completely faded but you can see the stampings on them. Any help would be appreciated. Wayne Avery (252 714 7261) ffwavery@aol.com
762luver
VT
I'm posting to this thread as it seems to be relevant to M416 restoration without starting a new thread.
I have a trailer with a loose bolt and nut holding my landing gear up and am getting tired of hearing it rattle around. I have the lock plunger and spring, but would like to finish the job with the plug for the hole.
What is the thread and "correct" plug for the landing gear lock?
Some people have told me that it is a pipe thread. It doesn't look right to me.
Thanks for the help.
Evil Dr. Porkchop
343
Colchester, VT
I just took one apart and it seems to be a typical 1/2” pipe plug. Both of the NOS m416a1 surge brakes I have use a hex style plug while a complete m416a1 and a couple older m416s have a regular square plug.
