harryhr
- 17
- 8
- Niagara Falls, New York
I purchased a 1967 M416 trailer which needs a lot of restoring. I started to pill out the old wheel bearings and the left side was easy to come apart and the bearings are junk. The right side is a different story. The wheel bearing race is froze solid to the axle spindle like it is one piece. I sprayed penetrating fluid in the spindle and race and let it soak in for three days, Tried again this morning to get the bearings out and it still won't budge and now the drum won't turn, it's like everything seized up. The other side was great. I just tapped on the back edges of the drum and it came right off with the bearings. I'm thinking maybe I can heat up the race and spindle with a welding torch and try to expand the race or just cut the race and bearings out with the torch. I am at a loss here. Any suggestions?? Thank you for any and all information and suggestions. If this doesn't work I will need to find a replacement axle with brake drums. If anyone has one for sale, please let me know. I'm located Niagara Falls, NY. If it's not too far, I will travel to pick it up. Thanks again, Harry
