m52..army vs. marine
M813A1
OKC, Oklahoma
Sometimes the Marine trucks have a locker unit in the carrier of the axle . My 5 ton M813A1 Army truck has a open carrier so both left and right side hubs do not turn at the same time if you get stuck
yeehaa
Austin TX
When I was in the Corps, all of our deuces & 5-tons had lifting shackles on the front bumpers and attached to the frames & beds on either side between the rear axles. None of the Army trucks I saw ever had them.
m16ty
227
Dickson,TN
All the trucks I've ever seen have lifting points on the front and between the axles.
Are you talking about something different than the standard lifting shackles?
yeehaa
Austin TX
On all of our trucks, the side shackles were always in place. They were long arms attached to the frame mount with a pin and stuck out a few inches past the bed. The Army trucks never had the arms on them.
jwaller
19
Columbia, SC
many of the marine trucks will have also had deep water kits on them. the larger lifting hooks on the front bumpers are referred to as paper clips.
