Csm Davis
- 382
- 83
- Hattiesburg, Mississippi
Is this a normal PS for this truck?
Whoops,Thanks AMGENERAL but it has a made by Jeep data plate, it's a Mack?
No biggie I might be wrong on a1 don't know a lot about these old ones.
SWISS and I have, rebuilt the selector valve, replaced the power cylinder, had the steering box completely apart to fix leaks on the RESTORED 55 m62 that MR. SWISS is RESTORINGAnyone done any troubleshooting on the Rossi Steering?
If I took pics of the Rossi system could you tell me which side is the pressure line?? I just want to make sure that its the pump is working before I pull the entire column. My IP is coming out at some point so it will be a no brainer to pull the pump if its bad.SWISS and I have, rebuilt the selector valve, replaced the power cylinder, had the steering box completely apart to fix leaks on the RESTORED 55 m62 that MR. SWISS is RESTORING
On the slector valve,If I took pics of the Rossi system could you tell me which side is the pressure line?? I just want to make sure that its the pump is working before I pull the entire column. My IP is coming out at some point so it will be a no brainer to pull the pump if its bad.
He means ROSS, just confused on the spellingRossi??? Is that an Italian retrofit?
